Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › necht cut out
- This topic has 6 replies, 3 voices, and was last updated 13 years, 10 months ago by
Devlin Maguire.
June 7, 2012 at 11:19 am #69824
Devlin Maguire
ParticipantI have a necht wqp12 -9319, not heating, element heats with remote power, and there is 240V at the element live and earth not at the Neutral, cutout is passing current ok, now there is another componant that looks like a stat but has live (pink) and neutral terminals is this another cut out and if so whats it purpose Thanks
DevJune 7, 2012 at 12:17 pm #376108kwatt
KeymasterRe: necht cut out
Basically, there’s no service or spare parts info on these at all unless one of the guys happens to now the dishwasher through seeing one before. It’s probably a Chinese Midea or Haeir but, goodness knows.
June 7, 2012 at 12:43 pm #376109Devlin Maguire
ParticipantRe: necht cut out
On further investigation it appears that the second thermal cut out breaks the neutral why they would do this is anyones guess I am going the bypass this and see if I get the element to work
I have bunged it in the freezer for the time being maybe it’ll reset
DevJune 7, 2012 at 1:14 pm #376110admin
This would more likely be a pressure switch which would stop the unit heating if there was not enough pressure to operate the unit correctly.
If you send me a photo to samsung@ffrservices.co.uk i will confirm it or not.Bryan
June 7, 2012 at 1:31 pm #376111Devlin Maguire
It is definatly a ksd201 stat there are 2 of them at differant places on the element there is also what I assume is a thermistor up into the controller right on the bottm of the eash tank it looks as if it should be glued with some sort of thermal paste and it has come adrift, I am getting current to the element now but the power to the elment does’nt stay on very long but this might be becuase the tank water level in never that high any making progress
DevJune 7, 2012 at 2:18 pm #376112admin
Putting in the freezer is a waste of time..It won’t reset if its a thermal cutout.
bryan
June 7, 2012 at 6:49 pm #376113Devlin Maguire
Thought as much Bryan after 2 hours it’s still open any way they are available as a pair one is re-setable at one aint got them on fleabay
Dev -
