Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Need advice on buying a vent hose
- This topic has 10 replies, 4 voices, and was last updated 10 years, 6 months ago by
yellow snow.
September 11, 2015 at 5:20 pm #86074
yellow snow
ParticipantI need to buy a new vent hose for a hotpoint aquarius tvm570p(uk) tumble dryer but would anyone know the original part number.
I’ve read that you can buy a clockwise vent hose and a anti clockwise vent hose but is there an truth in this.September 11, 2015 at 8:00 pm #430235iadom
ModeratorRe: Need advice on buying a vent hose
Part number is C00258633, as it is listed as vent hose KIT, I guess it will come with the connector.
As far as clockwise and anti clockwise I suspect someone has been winding you up. :rotfl:
Of course it could be the way the hose screws into the adaptor. :con:
September 12, 2015 at 4:33 am #430236yellow snow
ParticipantRe: Need advice on buying a vent hose
Thank you for the part number. I found the info about clockwise / anti clockwise on ebay.
http://www.ebay.co.uk/itm/Hotpoint-Drye … 4897.l4275September 12, 2015 at 8:54 am #430237iadom
It is as I thought, although TBH I have never even noticed the had the spirals going both ways, you learn something every day. 8)
September 12, 2015 at 6:46 pm #430238Martin
ParticipantNeed advice on buying a vent hose
iadom wrote:It is as I thought, although TBH I have never even noticed the had the spirals going both ways, you learn something every day. 8)
But if you thing about it, at one end of the coiled flexi vent hose you would need to thread any adapter (say) clockwise. But at the other end the opposite applies……go figure! 😉September 13, 2015 at 6:45 am #430239wizard
Not true Martin ! Do the threads go the opposite way on each end of a lenghth of metal studding ?
September 13, 2015 at 7:21 am #430240Martin
wizard wrote:Not true Martin ! Do the threads go the opposite way on each end of a lenghth of metal studding ?
Of course the thread goes one way as does the coil on any vent hose. The issue here is that at one end you will need to screw the threaded plastic adapter coupling clockwise and on the opposite end of the hose an adapter would need to be threaded anti-clockwise.
Much like a clock face. From the outside the hands go clockwise. Looking from the inside and they go anti-clockwise.
Have you got it now?
September 13, 2015 at 10:59 am #430241wizard
Go try it then Mr clever clogs !
September 13, 2015 at 1:05 pm #430242Martin
wizard wrote:Go try it then Mr clever clogs !
It’s not me that has the problem Wizzy.
September 13, 2015 at 4:09 pm #430243wizard
Have it your own way Martin, but do give it a try when you’ve next got a vent hose in your hand.
September 13, 2015 at 4:34 pm #430244Martin
Will do…….. :tup:
