Need exact dimensions for White-Westinghouse fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Need exact dimensions for White-Westinghouse fridge
  • #90864
    March25
    I want to replace an old fridge and need the exact dimensions. It’s a White-Westinghouse integrated refrigerator (fridge and chiller), model number WH926E. Does anyone know what the dimensions are or how I can get them? I’ve measured it with a tape measure but obviously just have the approximate measurements.
    Thanks in advance!
    #446258
    Re: Need exact dimensions for White-Westinghouse fridge
    I do think you’ll struggle with that unless someone happens to have an old brochure or something kicking about as they ceased trading about 2008.
    But it should fit in a standard sized kitchen unit.
    March25
    Hi K
    Thanks for your reply. Would you recommend just measuring the cabinet (easier to do) and getting a new fridge that is slightly smaller? Would I have any problems fitting the new fridge into the existing cabinet this way?
    #446260
    Should be in a bog standard 600x600x850 cabinet so pretty much anything should fit. You’re problem may be the door and that is a total unknown.
