Need explaination on C/D parts
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Need explaination on C/D parts
  • #16111
    Fairdeal
    Could anyone one kindy explain the functions of the two stats on a tumble dryer i.e. the one shot and cycling sensors.Also if you could expalin the relay function as well.
    #167579
    gegsy
    Re: Need explaination on C/D parts
    The 1 shot stat is a thermal overload ie over heat due to many reasons, fan failure,vent blockage etc.
    Thew cycling stat is as it says, it cycles the temp of the drum to the correct working temp.
    The relay is used where a low voltage and current can switch larger loads ie heating elements.
    bobokines
    The relay on condenser dryers is a latching relay that ensures that someone has to be present to turn the appliance on. This is due to the large loading door which is large enough for a child to climb in.
    Bob
    #167581
    Fairdeal
    Thanks very much for the explainations, it has cleared my concept of these parts.
