Need help!
  • #76495
    Cheekylu
    I live in a small rented flat and the washing machine is very old, I’ve even been told if the washing machine breaks they can’t repair it as its that old they don’t make parts for it anymore.
    Anyway my problem is this I bought a new bed set and sheet put it in for wash and there is pulls all over the fabric everywhere very large around at least 5 different pulls and the fabric stuck together.
    Is this the washing machine causing this? Or is it the fabric? I’m worried to put anything else in there.
    #398525
    Muv
    Re: Need help!
    Check the plastic paddles inside the drum are intact and correctly seated…also check for any damage to the holes in the drum …mind your fingers, it will be very sharp!
    Cheekylu
    Re: Need help!
    Thanks for getting back to me, I have ran my hand around and not felt any sharp bits, also the paddles are not plastic just all stainless steel like the whole drum nothings come apart :/
    #398527
    Andy jones
    Re: Need help!
    What make is the machine ? Is it a washer dryer
    #398528
    Cheekylu
    Re: Need help!
    I’m not sure it’s so old I think it was made in Italy and has 2 different names might be a Servis? Or something beginning with a c it doesn’t even say and yes it’s a washer dryer
    #398529
    Allsorts
    Re: Need help!
    Check to see if there is upwards and downwards movement of the front of the drum… If yes, the drum could be catching the materials between the drum and the edge of the seal
    #398530
    Andy jones
    Re: Need help!
    In my opinion the biggest cause of damage to clothing is customer misuse
    Make sure you are selecting the correct cycle for the type of fabric you are washing
    Most common comment I get is ” we only use 1 cycle”. Therein lies the problem
