Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › need help assessing wm noise please
- This topic has 5 replies, 5 voices, and was last updated 9 years, 2 months ago by
rst122.
January 17, 2017 at 7:06 pm #90362
rst122
Participantuploaded a yt video for assessment. seems to make the noise when its cold. summertime it doesnt make it but obviously there is an issue. thank you
https://www.youtube.com/watch?v=KrM029npl2oJanuary 17, 2017 at 10:15 pm #444544clivejameson
ParticipantRe: need help assessing wm noise please
The noise appears from the video to coincide with the rotation of the drum which suggests it’s a foreign object caught behind it.
You can try putting your head inside the drum and rotate it by hand…it can be difficult but you may be able to hear the location of the noise…most likely near the bottom.
If you’re lucky you may be able to see it through the holes in the drum using a torch.
Where it is exactly will determine which access you need to remove it.
January 17, 2017 at 10:48 pm #444545rst122
appreciate the quick reply Clive. I opened the door and spun the drum by hand and its making no noise at all. its very smooth and quiet. I will open it to check inside.
any idea why the noise when working but none when rotated by hand?
can you tell me what I need to check when the washer doesnt fill with enough water? I manually add water. its basically only filling partly and I fill it with another 12 liters or so to get it at 1/4 of the level up on the door.
cheers
January 18, 2017 at 12:05 am #444546Martin114
Sounds like belt slip to me
January 18, 2017 at 9:15 am #444547iadom
ModeratorRe: need help assessing wm noise please
Fill levels are almost certainly correct, all modern machines use much lower water levels than a few years ago. Very few modern machines will fill up to the lower lip of the door glass on the wash cycle, some will fill a little higher for the rinses.
Does it still make the noise if you don’t ‘overfill’ it? The door seal could be catching on the drum or it could even have a cracked drum support. Is it excessively noisy on fast spin with a full load?
As Martin suggests, belt slip can also cause noise but that sounds like a scraping noise.
January 18, 2017 at 1:07 pm #444548Martin
I’ve just trained my good ear to the short video and concluded it is the belt that needs replacing. Check the main drum pulley is secure on the central shaft whilst you’re at it.
