Need help Identifying Cooker (Valor Newhome Model 351-70)
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Need help Identifying Cooker (Valor Newhome Model 351-70)
  • #39464
    malcolmm
    Hello all,
    A while ago while making pasta, I managed to splash some water into the cooker causing a big BANG as something shorted out somewhere and the fan stopped working. This makes the cooker somewhat unsatisfactory as I can’t run the grill or the front rings at too high a heat, or it overheats and then cuts out …
    I finally got around to disassembling the thing today, and found the motor seems fine (still haven’t checked it completely) but I seem to have shorted out the control board which drives the fan. And now of course this is where I start to hit problems…
    Problem no. 1: There is no make or model information anywhere on the cooker. It may have originally been on the glass hob cover, but that vanished long ago… Of course without a precise idea of the model, getting any spares might be tricky.
    There is a rating plate in the area just under the rings which tells me the following:
    VALOR NEWHOME LTD
    PRESCOTT MERSEYSIDE L35 2XW
    MODEL NO……… 351-70
    SERIAL NO……… 000441
    VOLTS…………… 240 AC
    HEAT WATTS…… 10650
    MOTOR WATTS… 29
    TOTAL WATTS…. 10679
    Needless to say, searching for the Valor Newhome 351-70 has produced zilch results … Does anyone know what make and model I should be looking for? Or is this thing so old I am outta luck?
    The circuit board in question has the following on it:
    Bottom left, solder side: DIAMOND H CONTROLS
    Left hand edge, solder side: T?5 (may be T65) EC110B
    Right hand edge, solder side: 23-408 Iss. ? (looks like a 2). Overstamped over the maybe-2 in white paint is ’28-6′
    Top edge: 23-433 ISS. 6
    Bottom RH corner: Two Hs sort of stacked up and joined together. A bit like this:
    H
    .H
    Problem no. 2: A small but vitally important problem. I made a schoolboy error during disassembly and don’t know which way round I should reconnect the fan (if I ever get that far, I think with the age of the cooker I might be on a hiding to nothing). One side went to live, one to the post marked LAMP on the PCB. Problem is I can’t remember which and getting it wrong = another blown PCB ;). they are coloured in normal ‘modern’ Live and Neutral colours (brown and blue), but not sure which went where. I am pretty sure one side went to Live but always best not to make assumptions …
    If anyone can help me with my aging cooker, it’d be much appreciated. Although at the moment I’m leaning towards wiring it up so the blower’s permanently on (if it still works – not yet verified!) and switching it on/off at the wall instead, until I get a new cooker ….
    Thanks!
    #262497
    malcolmm
    Re: Need help Identifying Cooker (Valor Newhome Model 351-70
    Update: Fan motor confirmed as U/S. I plugged it in, there was a nice big BANG, and that’s that I think!
    However this did give me the oppo to disassemble the fan assy and find the OEM of the fan unit, plus a date, so I now know the cooker was made in the mid 1980s and is about 23 years old …
    The fan assembly is made by S.T.C COMPONENTS and is datestamped 8 MAY 1985. On the motor, we have:
    240V. 50 HZ
    STC10A-030.135
    In turn, the motor itself is made by Mycalex Motors UK.
    Hopefully a bit of Googling will at least find me a replacement fan assy…
    #262498
    Something like THESE?
    AC circuit, so polarity to fan motor not important.
    malcolmm
    Penguin45 wrote:Something like THESE?
    Exactly like one of those 🙂
    Now, I only have the burnt out control board to deal with … Or just go for hardwiring it to always on; replacement PCB might not be worth the money considering I could probably get a complete working cooker for free from Freecycle or somesuch …
    Thanks!
