Need help with a candy cwb110-80
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Need help with a candy cwb110-80
  • #85658
    Stu21t
    I’ve just fitted new bearings to my cwb110-80 washing machine and now it won’t turn on.
    If I turn the main switch to any setting I get I faint hiss from the pcb and the stop light flashes as normal but when I press the start button nothing works, the stop light goes out and the pcb stops hissing. 5s later the stop light flashes again and the hiss is back.
    It was working fine this morning.
    All the other buttons work like the delay/rapid… They light up when pressed as normal.
    And the rest of the lights (timer/hrs lights)
    It’s only when I press the start button that the stop light goes out and the hiss stops
    Any ideas?
    Everything is connected as it should be.
    #429219
    Re: Need help with a candy cwb110-80
    It sounds like you’ve connected something wrong and the PCB may now be defunked.
    Double check all the wiring to which hopefully you took photos of all the wiring connections to ensure you refit correctly ?
    Bryan
    #429220
    Stu21t
    It does seem like its tripping out.
    But I can’t have connected it wrong as all the plugs only fit in the correct places, you can’t put the plugs in the wrong place.
