Hi there, hope you can help. I noticed a previous entry in the forums where someone asked for a manual for a Homark oven. I have just moved in to a place, and this unit is installed, so was trying to get a manual for the unit: Homark 01-711000 brown type FES170 SN 5970918000-612842.
The other factor is that I am trying to locate a replacement Function switch for the unit, and trying to find spares is a bit of a problem. If possible, please point me in the direction of a supplier, and if available, confirm what the part number for the function switch is.
I believe I have found the part, on your site, but need to confirm that this is the function switch and not the temperature switch, and if it includes the outside dial (since mine is broken off) also is it in stock for ordering.
Thanks for your help.
