Need new integrated fridge freezer 70/30
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Need new integrated fridge freezer 70/30
  • #81771
    Chrissym
    Hi everyone
    We need to replace our electrolux ERF2831 70/30 which has stopped working.
    We have a cupboard that is 560mm deep, 560mm wide and 1950mm high, the door has been reversed and is on a sliding fitting.
    Can anyone recommend a brand or even a model that would fit? We don’t want to spend too much maybe £300ish as we are planning on moving. We are in the Stockport area if anyone can suggest someone local.
    Also the original fitters did not leave a ventilation vent in the top of the cupboard, in fact they fitted a shelf directly on top of the FF. Will we need to have one cut out?
    Any help would be appreciated..
    Thank you
    Chrissy
    #417657
    don
    Re: Need new integrated fridge freezer 70/30
    Hi Chrissy
    This Beko BC73F is about all there is in a brand name sub £300. Yes it will take the sliding hinge system as well.
    Any reputable kitchen installer will be fit and cut a ventilation hole. I would ask family, friends and neighbours for a recommendation as word of mouth is probably the best way of securing good tradespeople.
    HTH 🙂
    Don
