Need to buy a freezer 20″ wide.
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Need to buy a freezer 20″ wide.
  • #19488
    helenb
    Need to replace my counterheight proline freezer which is 20″ wide.Would like a taller one.What can u suggest?I dont particularly want to buy from currys or comet.edited-would like to increase capacity of my freezer.
    #183360
    Dave_Conway
    Re: Need to buy a freezer 20″ wide.
    There are very few to be honest, it’s even quite limited trying to get under counter 50cm fridges and freezers these days let alone taller ones 😕
    The only one I can find is a Baumatic BZ190 (Google the model number for more info).
    A local independent retailer should be able to order it for you 🙂
    #183361
    don
    Or as a compromise how about a 50cm wide fridge freezer with a small freezer attached either at the top like the Whirlpool ARC2130 or the Lec T5006 which is on the bottom. At least you are increasing the fridge capacity.
    Just a thought.
    Don
    #183362
    helenb
    Thanks ,but I already have a built in fridge in my kitchen-this freezer is in a utility room and i want to increase the size of the freezer,not decrease it.
    #183363
    don
    😳 should have cleaned my glasses first 😀
    Looking through the A-Z of maistream manufacturers the narrowest I can find is the Zanussi ZEUC1825 but it is 55cm wide, 125 cm high and has a 6 cu foot capacity. Can you gain a little more width ❓ .
    Don
    #183364
    helenb
    Unfortunately the doorway is just under 54 cm wide.
    #183365
    Dave_Conway
    Baumatic BZ190W Kitchen Appliance
    190 Litre Freestanding Freezer
    Features:
    * gross capacity: 190 litres
    * net capacity: 155 litres
    * Energy efficiency class: A
    * Star rating: ****
    * manual defrost
    * adjustable thermostat
    * 7 freezer drawers
    * reversible door
    * adjustable feet
    * Dimensions: H1421mm W500mm D580mm
    :hide:
    #183366
    don
    Baumatic it is then :tup:
    Don
    #183367
    helenb
    thanks to you all.
