Customer had a major milk boil-over on hob above cooker – timer covered in ‘burnt’ milk inside and around contacts.
Since spill, top oven/grill element does not work – no supply at element tags. Grill element fine, main and top oven cut-outs ok, top oven fan cut-in ok. Top and lower oven thermostats ok. Top oven/grill selector switch looks ok.
Top oven lower element heats when top oven selected.
So reasonable to assume timer was the problem. But when fitted same problem. I marked leads before remove from top but when put back the marks rubbed off – now I don’t trust myself to have replaced them correctly. 😯
Need a wiring diagram for above – prod 944171377.
I need to check the timer wiring – any ideas for pointing me in right direction or can any one email me a copy.
Laurence
