NEF B1421 OVEN
  • #12032
    merlin45
    The door on my NEF B1421 Oven is failing to snap shut with no obvious signs of obstruction. The gap is just enough to let the heat escape.
    Has anyone any experience as to what may cause this and is there a simple remedy ?
    Thanks ❓
    #147592
    Simon46
    Re: NEF B1421 OVEN
    Sounds like worn hinges and or receivers.
    Regards
    Simon.
    #147593
    merlin45
    Re: NEF B1421 OVEN
    Thanks Simon46,
    I thought that might be the case but after only 2 years use I had hoped for more endurance.
    #147594
    Re: NEF B1421 OVEN
    Hinges are p/no 096784 (l/h), 096785 (r/h). Email to spares@ukwhitegoods.co.uk for ordering and confirmed pricing.
    merlin45
    Re: NEF B1421 OVEN
    Thanks Penguin45, your help is appreciated. 😀
    #147596
    Fatboydw
    Re: NEF B1421 OVEN
    I’ve got the same problem with my Mum’s Neff B1420 oven (E-NR B1420B0GB/03), but couldn’t find any hinges for it on the UKW site – could someone tell me what parts to order, and how difficult they might be to fix?
    I’m reasonably handy with the spanners, but have never replaced oven door hinger before 🙂
    Cheers,
    Grant
    #147597
    nomadPaul
    The two hinges are the same part numbers as above – 096784 and 096785 but these are BSH ( Bosch ) part numbers – ring 08448928921 to order spares – approx £13 Per hinge
    Its not too difficult a job if you have some basic DIY skills – Remove the door from the oven and then undo the screws on the door to release the outer and inner door panels , revealing the hinges .
    Check out the parts finder on the BSH website for your oven and you will see an exploded view of the door . This should explain everything pictorially
    #147598
    Re: NEF B1421 OVEN
    You can get them through UKW by mailing spares@ukwhitegoods.co.uk with the part numbers, for a similar price.
    We need the money to keep the site afloat, after all. 😀
    Fatboydw
    Re: NEF B1421 OVEN
    Thanks for the help guys – I have emailed UKW – it’s not the first time I’ve bought parts from them, but it is the first time I didn’t find the answer on the forum straight away and had to ask 🙂
    Cheers,
    Grant
    #147600
    nomadPaul
    Re: NEF B1421 OVEN
    Penguin45 wrote:You can get them through UKW by mailing spares@ukwhitegoods.co.uk with the part numbers, for a similar price.
    fair do’s , oh flightless one. It was only because he said he couldn’t find them on the site……my apologies 8)
    #147601
    Re: NEF B1421 OVEN
    :p45:
