NEF S51M53X1GB – filling with clean water when off
Home Forums Public Support Forums Help And Support Dishwasher Help Forum NEF S51M53X1GB – filling with clean water when off
  • #103669
    timo75
    Hi.. Recently my Nef dishwasher always had a pool of water at the bottom of the inside after a cycle. I thought it was a drainage issue so checked the pipes, the impeller, blockages etc and all good. Then I noticed that throughout the day when the machine was off the water level rose and it was clean water. So I think it is on the inlet side that the issue is. I have an aquastop under the sink on the supply pipe into the inlet valve at the base of the machine. I tried turning the power off but the water still rose so I turned the water supply off and that stopped the level rising. Do you think I can assume I need to get a replacement aquastop supply pipe with the inlet valve built in at the end to stop the water leaking in? The part I have found is below. Any help or advice would be gratefully accepted. Many thanks
    https://www.partscentre.co.uk/dishwasher-aqua-stop-water-valve-and-hose-299756.html
    #494141
    Just to be sure as there are a few versions, what are the numbers after that model, it should have a /** where “**” is two digits?
    They show it as a separate aqua stop valve on that model and it ain’t cheap, £85+ not cheap!! Which is, ehm, a bit sore I’ll say to be kind about it for a poxy inlet valve.
    However, from what you describe I’d say it’s almost a sure thing that that valve is the problem.
    timo75
    Hi, thanks for replying. The model number is S51M53X1GB/01 Thank you for your help.
    #494143
    That was the one I checked and it is that expensive valve I got being used on it.
    timo75
    hi.. sorry so do I need a different part no to the one I showed in the orig post? Are you able to let me know what I should be looking to source and replace? many thanks
    #494145
    Yes, according to the info it is part number 00645701 you need.
    timo75
    thats so helpful!!! thank you so much!.. I’ll ordder it and let you know how I get on… many thanks!
    #494147
    timo75
    kwatt wrote:Yes, according to the info it is part number 00645701 you need.
    Just wanted to say thank you! I fitted the part today and the issue seems to have gone away!
    many thanks for your help
