Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Neff 1420 fan problems
- This topic has 12 replies, 4 voices, and was last updated 19 years, 2 months ago by
stinky.
February 6, 2007 at 7:37 am #24798
stinky
ParticipantIthe fan on my neff 1420 oven appeared not to work but when removed and checked on a bench it ran ok
does anybody know what else i can check i have no circuits etcFebruary 6, 2007 at 9:25 pm #203347Penguin45
ParticipantRe: Neff 1420 fan problems
Any heat?
February 7, 2007 at 8:34 am #203348stinky
The circular element around the fan seems to be OK as I can see the element glowing red.
I have not left it on for any length of time to see if the oven gets hot. When I power the fan up with 240 volts on a bench it runs OK
Thanks for your replyFebruary 7, 2007 at 8:51 am #203349gegsy
stinky wrote:When I power the fan up with 240 volts on a bench it runs OK
Please note that we at UKW do not recommend nor see the need for this sort of LIVE testing. With a decent ohm meter the reading/s needed can be obtained. ❗
Does the fan motor spin freely if you spin it by hand and not sluggish?
We will also need ful Enr number, usually found around door opening on a silver plate.As for circuits etc may I refer you to http://www.ukwhitegoods.co.uk/modules.p … pic&t=4361
February 7, 2007 at 10:01 am #203350stinky
I have measured the resistance across the motor and have 92 Ohms.
Thank you for the advice, I am a fully qualified electrical engineer (HNC) so I am aware of the dangers of live testing.
The fan turns ok by hand and makes no unusual noises
I just need to know if there is a fuse or thermal trip in line with the fan motor that I can locate and check. If there is nothing else in line then could the problem be in the selector switch. I do not want to spend £65 on a fan and find it does not do the job.
I appreciate the helpFebruary 7, 2007 at 10:30 am #203351gegsy
stinky wrote:Thank you for the advice, I am a fully qualified electrical engineer (HNC) so I am aware of the dangers of live testing.
That is of no significance. What we have to consider is the amount of general public that may read this and TBH any posts in the public forums, who may not be as aware of the potential dangers as you or I 🙂
For me to go any further I would need that full model number as requested please.Greg
February 7, 2007 at 10:57 am #203352stinky
I take your point.
At the moment I am in my office I will get the full details and inform you of them as soon as possibleFebruary 7, 2007 at 2:00 pm #203353stinky
Greg,
The E No is 1420KOGB or another number on the model plate is FD 7701
Just traced wiring at lunchtime and thethe supply live and nuetral get to the fan terminals via the oven switch assy and a block (about 10mm square that is short circuit) . Although the live side has to come through the programmer board. As the element comes on can I assume that the supply is getting to the oven switch. If it is then I am puzzled why it does not run the fan 😕
February 7, 2007 at 3:42 pm #203354gegsy
Im taking model number as U1420K0GB/01.
Looking at wiring I would imagine that if you have heat and no fan operation then its looking like a faulty selector(S9) IMHO.Greg
February 7, 2007 at 4:15 pm #203355BSH-MAN
Somtimes 😳 the fan motors can get “gunged” up.
You may have freed up the motor just by turning the shaft.
Are you sure there was no voltage to the fan when it was on the oven?February 7, 2007 at 6:52 pm #203356gegsy
Good point, but without LIVE testing, did you hear a hum coming from fan motor when oven activated as that also will indicate what BSH MAN has said, and only a motor replacement will be the only option.
February 8, 2007 at 8:36 am #203357stinky
Thank you for the help i put it all back together last night and checked operation at each stage. Tha fan did not work at final stage with large cowling on. I am resigned to ordering a new fan and fitting that.
February 8, 2007 at 2:59 pm #203358BSH-MAN
Did it work fitted to the oven but with the cowling off?
If so, check the inside of the cowling for fat deposits that may catch on the fan blade. -
