Neff 5453X0GB/13 dishwasher overfill
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff 5453X0GB/13 dishwasher overfill
  • #33560
    Simon46
    Went to this one before XMAS. Dead. Fitted 264635 Module all working. This year it was reported water leaking down the door during wash and has filled the floor area behind the plinth. Base is flooded with dirty water. Pulled it out stripped run and tested no leaks. Even forced it to overfill and red float rises ok. Xfer hose clear. Stumped as to why so much water would come out.
    Any ideas?
    Regards
    Simon
    #239161
    superfix
    Re: Neff 5453X0GB/13 dishwasher overfill
    Bottom spray arm not clipped together properly or bottom door seal come away ❓
    #239162
    aqualectric
    I’ve had a similar problem and it was the seal under the door. Remove the door outer skin and the seal spans the gap between the bottom of the door and the tray. The machine I saw had a distorted seal and it had popped off the lip of the tray.
    I’ve had several Bosch machines with torn or split ones as well. (They are “entertaining” to fit – best way is to release the spring before removing the old seal: doing the job with a sprung – loaded door is like wrestling an alligator).
    HTH,
    Steve.
    #239163
    superfix
    aqualectric wrote:doing the job with a sprung – loaded door is like wrestling an alligator).
    HTH,
    Steve.
    Almost impossible, if you want to keep your fingers 😀
