😕 I am considering buying my DISABLED RELATIVE a Neff integrated oven because it has a door which when opened slides downwards and into a horizontal slot at the the base of the cooker. This wd greatly help her to safely use the oven, and avoid the width problem in a galley kitchen when the oven door is extended open. Reviews look fairly good, but it is expensive – my concern is – DO YOU THINK THERE COULD BE PROBLEMS WITH THIS DOOR after some regular use? ie would it start sticking or jamming in the slot – then it would be a major fault. Wd much appreciate any comments from trades/sales people – thanks
