Neff B1320 tripping RCD?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff B1320 tripping RCD?
  • #36805
    favill1982
    Hi, have a Neff B1320 and noticed a few having similar problems with. However was using oven and suddenly tripped RCD. Oven was still hot so turned back on but as soon as the thermostat ‘clicks’ to increase oven temp it trips it off again. If you turn the temp down the fan, etc still is on? Is this the thermostat causing the trip??? And if so how much is it? Please help! 😥
    #252433
    Brains
    Re: Neff B1320 tripping RCD?
    probably the element has failed.
    Turn the power off before investigating.
    #252434
    Good outline information HERE.
    Relacement element is p/no 262180 – spares@ukwhitegoods.co.uk will be able to get one for you promptly.
    Power off if you intend to sort this yourself.
    favill1982
    Is it definately the element? Just tried it again this time on the grill only and as soon as u turn up the temp dial it trips again??
    Penguin45 wrote:Good outline information HERE.
    Almost certainly an element – you’ll need to get in there with a test meter and track it down to be sure.
    Is the grill selected by moving through the oven temperature?
    favill1982
    No the controls are separate. Defrost, Oven and Grill on one side and on the other side is the temp dial which is also linked to the grill temp Low Med and High. As soon as the temp dial clicks either on defrost, grill or oven setting the RCD trips. The grill has its own element across the top and the fan has an element around it also? Any Ideas?
    Penguin45 wrote:Almost certainly an element – you’ll need to get in there with a test meter and track it down to be sure.
    gegsy
    I would check each element in turn (disconnected) using a megger.
    That will eliminate the errant part 😉
    favill1982
    Shall have a go at that. Is it definately not the thermostat then? I had seen this mentioned in a previous post by bryan but wasnt sure
    gegsy wrote:I would check each element in turn (disconnected) using a megger.
    Thermostat simply makes and breaks the circuit – unless it has an internal fault to earth, which would cause a short. Very unlikely.
