Neff B1322N1GB oven installation question
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff B1322N1GB oven installation question
  • #30718
    Parp
    We’ve got a Neff B1322N1GB built-in fan oven + grill on order and due to be delivered early next week and I’m just trying to get everything ready for it. Our current oven ( Diplomat ADP3101 fan oven + grill ) is just wired into a 13A plug that fits into a socket behind the unit, under the worktop.
    I believe the Neff is rated at 2.8Kw ( I think the Diplomat is around 2.3Kw ), so will I be able to use the same method ie 13A plug or will I need to get a proper cooker socket installed. If the latter, can these be connected to the normal ring ( 2.5mm T+E ) or will it require a heftier cable? I’ve not checked the wiring yet so it may already use bigger cable.
    Any advice much appreciated.
    #228163
    superfix
    Re: Neff B1322N1GB oven installation question
    Will be fine on 13 amp plug, unless installation instructions say different.
    Max load will be roughly 11.5 amps 😉
    #228164
    Parp
    Many thanks for that Superfix. That’s the answer I was hoping for.
