Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff b1420
- This topic has 7 replies, 4 voices, and was last updated 15 years, 4 months ago by
ddirect.
November 17, 2010 at 6:15 pm #58940
ddirect
ParticipantHi all going to see a neff b1420 built in oven tomorrow,
the problem reported is that if the thermostat is set just below 150 degrees it will work all day no problem, but as soon as you go above 150 degrees the oven trips the electric, the only thought going through my mind at the moment is, that the top cooling fan is not working,therefore activating a toc which in turn gets to hot then trips the electric,any thoughts welcome.
DarrenNovember 18, 2010 at 1:06 am #336225leavemetogetonwithit
ParticipantRe: Neff b1420
Think fan element is cheap enough for these. I’d try that first before imagining all sorts of complicated faults :wink:. Check fan speed too. If it seems a bit slow, pull cooker out and lubricate fan bearings.
Mike.November 18, 2010 at 8:46 am #336226ddirect
Mike do you not think if it was fan element it would trip no matter what temperature, after all the element will heat till the regulator cuts it out, so if it was element, i would have thought it would trip no matter what temperature, i know we get elements that go open circuit after a short period of time after the appliance is switched on, so i understand your reasoning.
and yes your probably right, i may be putting to much thought into this, and like you say, the element aint that expensive so trying one would be a quick way to rule it out or possibly fix the problem.
thanks for your thoughts.
DarrenNovember 18, 2010 at 8:55 am #336227Martin
ddirect wrote:the only thought going through my mind at the moment is, that the top cooling fan is not working,therefore activating a toc which in turn gets to hot then trips the electric
Yep, I think your on the right track with that theory Darren.:D
November 19, 2010 at 12:33 am #336228leavemetogetonwithit
Sorry, I thought you meant tripping the trip-switch at the consumer unit.
Mike.November 22, 2010 at 5:33 pm #336229ddirect
Thanks for comments, and Mike you seem to be right, replaced element and everything seems ok.
but to be honest still dont understand why, its not like you can turn on an element to half heat, it goes full blast till temperature reached,
could someone educate me.lol
also like to thank Martin for his input.
thanks again Darren Bewildered. but happy its working.November 22, 2010 at 11:43 pm #336230gandh1
when this has happened on the odd occasion to us, and has also baffled us, only conclusion we have come to is expansion/contraction through heat…
i.e. as element heats up, it expands, whereby more prolonged heating expands it further, stretching the insulation so a hairline split allows a short to earth. hence short bursts of heating say to 80-150* as you have experienced seem to work fine, because it hasnt been hot long enough to expand. however, if you look at the element youll almost always spot a “floppy” bit or slightly bloated
November 23, 2010 at 1:56 am #336231leavemetogetonwithit
It’s a bit odd but no less odd than your original theory would have been. I mean, why would a toc opening blow the trip?
The hotter the oven temperature rises, the slower the rate that heat can escape from the element surface. It will draw max. current right away but the air blowing over it keeps it (relatively) cool.
Mike. -
