Neff B1420 oven
  • #29918
    multiplexor
    Hi, i am trying to find out how to change the thermostat on the oven mentioned above. The oven will only partially warm up but will not heat up to the temperature which has been set. I would appreciate any suggestions.
    Multiplexor
    #225188
    gegsy
    Re: Neff B1420 oven
    Is the fan in the oven at the back running ok?
    multiplexor
    Re: Neff B1420 oven
    Hi Greg,
    Thanks for your reply. The fan at the back of the oven isn’t running although i could see the element next to the fan heating up from cold. Is it likely that the motor has burnt out and if so, is it an expensive item to replace?
    Mike
    #225190
    gegsy
    Re: Neff B1420 oven
    Off the top of my head £60+ the usual.
    If you can supply the full model number which will be around the main oven door opening, I can get you the p/no fo ryours.
    multiplexor
    Re: Neff B1420 oven
    Hi Greg,
    the model number is E-Nr B1420W0GB/05
    Is it easy to get to the motor to change it?
    Mike
    #225192
    gegsy
    Re: Neff B1420 oven
    You will need p/no BS14106 for the fan unit complete and from experience you would do well to replace the circular element aswell. p/no
    ELE2044. Both spares available from spares@ukwhitegoods.co.uk
    The element can be changed form the front but the fan motor will require access to front and rear.
    Power off if you are to attempt yourself or find an engineer from the link below 😀
    multiplexor
    Re: Neff B1420 oven
    Thanks for all of the information Greg, I will order the parts tomorrow and will wear my thickest wellies while fitting the motor!!!
    Cheers
    Mike 😉
    #225194
    gegsy
    Re: Neff B1420 oven
    Power off will suffice, wearing wellies while doing it is a tad erm kinky 😆
    multiplexor
    Re: Neff B1420 oven
    Well if you insist, i will just turn off the power then……
