Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Neff B1430 oven query
- This topic has 7 replies, 3 voices, and was last updated 18 years, 4 months ago by
keybored.
December 7, 2007 at 7:35 pm #32834
keybored
ParticipantOven decided not to heat up today 🙁 fan is blowing so assume heater element has gone. Have ordered replacement but was wondering if it can be replaced from inside or do I have to take the oven unit out. Thanks in advance for any help.
December 7, 2007 at 9:34 pm #236562Penguin45
ParticipantRe: Neff B1430 oven query
I *think* you can fit this one from the front.
Power off, though.
December 7, 2007 at 9:53 pm #236563keybored
Thanks for that; I suppose what I should have asked was whether it was simpler to take the unit out and replace the heater element from the rear rather than trying to do it from inside the oven. I installed it myself and left plenty of slack in the mains cable for such contingencies. I will of course isolate the mains before working on it 😀
December 7, 2007 at 10:28 pm #236564Penguin45
Take the inner rear panel off to reveal the element. If you can see screwheads, you can do it without taking the unit out.
Nice long power cable was a good plan though. 😀
December 7, 2007 at 11:00 pm #236565keybored
Thanks Penguin, you’re a star! Getting grief from ‘er indoors as she wanted to use it this weekend :rolls:
December 8, 2007 at 10:46 am #236566keybored
Well I managed to remove the old element and sure enough it meters as dead, but I notice that the element I have on order (ELE2044) no longer has the earth connection, which seems a bit of a backward move to my way of thinking, or am I missing something? Surely it’s better to have a solid earth connection rather than relying on the chassis screws. So am I right in thinking I just need to lose the existing earth wire somewhere safely out of the way as it is now redundant?
December 8, 2007 at 11:12 am #236567gegsy
Centre earth tag not been used for years on these elements 😉
If you are worried about poor earthing of element via chassis, I wouldn’t 😀
Im sure you aren’t goint to be touching the element under normal operation 😆Greg
December 9, 2007 at 12:17 pm #236568keybored
Thanks gegsy, you guys are much appreciated 😀
