NEFF B1432 Oven not heating up
Home Forums Public Support Forums Help And Support Cooker And Oven Forum NEFF B1432 Oven not heating up
  • #33305
    scottieU
    Went to use the oven today and no heat. Under the oven selection, the fan, the light and the heating element power light are all on, but no heat.
    The grill works fine but with the grill/fan option, the fan does not work. From reading all the ohter topics I believe it is the fan element – what do you think?
    The details for the oven are :
    ENr B1432N2GB FD8406 B-AP22-7
    I noticed from some of your links this model does not appear. Can you recommend the correct element (if thats what is required) and expected delivery – looks like a cold buffet for New year then !!
    Scott
    #238229
    gegsy
    Re: NEFF B1432 Oven not heating up
    I would imagine it is the circotherm element that has failed IMO. 😀
    Only a check with a multimeter on ohm settings across its terminals would confirm. Power off before attempting this :plug:
    Part is available from spares@ukwhitegoods.co.uk quoting p/no ELE2044 😉
