Neff B1441WOGB/04 (built in oven)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff B1441WOGB/04 (built in oven)
  • #52806
    rocker
    need to change over lamp assemble, the orginal one has a toc/ stat fitted to it…the new one hasn’t..rang bosch for advice, they tell me I have correct part, but it has been changed ie. no toc / stat fitted but won’t give any advice as to the toc, does anyone know the answer, also I can’t remove the org part. do I replace with a new toc or by- pass!!
    any help please. John.
    #313205
    superfix
    Re: Neff B1441WOGB/04 (built in oven)
    You fit the toc off the old one onto the new one.
    #313206
    rocker
    Superfix, I tried to remove, but not sure how its fixed, cant see any screws ect, can you let me know, thanks john
    #313207
    nomadPaul
    Superfix is correct. The original TOC has a small nut on the inside. Its a bit fiddly to fit and best to do it before fitting the new lamp assy .
    I take it that it’s the lamp assy fitted in the top right back corner ?
    The original lamp is held in with ‘sprung clips’ around the lamp body. Theres 4 IIRC . You will need to access it from the back and push the clips in whilst gently pushing the lamp assy out into the oven cavity. Best put an old towel down in the oven base as unless you have arms like a chimpanzee or an assistant , you can’t reach inside whilst pushing the old one through.
    You’ll also find that you’ll prob have to bend the lamp connections on the new part ( 424077 ? ) to allow proper connection of the cables and to stop them touching the casing.
    #313208
    rocker
    Thanks for your helpful reply Paul. John
