Neff B1451N0GB/01 Grill problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff B1451N0GB/01 Grill problem
  • #20273
    Maverick
    We moved into a new house in which there is a Neff B1451. Everything works fine except for the grill which does not get hot enough to cook anything. It gets too hot to touch, but no hotter. Today I removed the back cover of the oven and tested the grill element with a multimeter. I got 30 ohms on the inner element and 50 ohms on the outer element. What more should I check?
    Thanks in advance for any advice.
    Cheers
    Hingy
    #186451
    superfix
    Re: Neff B1451N0GB/01 Grill problem
    Do you grill with the door open or closed?.
    #186452
    Maverick
    I’ve tried with both and get the same result.
    #186453
    gegsy
    When you close the door, does it thud shut and seal tightly??
    Maverick
    Hi Greg
    Yes, it seals tightly. We think that only the grill function is faulty because we made a crumble using the Circotherm setting and it came out perfect. We have cooked roasts as well and the timings have been correct.
    Cheers
    Hingy
    #186455
    gegsy
    Same thermostat for oven and grill, so thermostat must be ok.
    Have a look and see if temperature probe in oven cavity is secured and not touching grill element?
    If you have to remove panels in the future again please make sure you unplug appliance or isolate at spur or fusebox.
    Maverick
    Hi Greg
    Is that the horizontal metal tube at the back of the oven?
    Cheers
    Hingy
    #186457
    gegsy
    Yes capillary then wider part at end
    #186458
    Maverick
    Hi Greg
    Thanks I’ll have a look.
    Hingy
