Neff B1476N2GB/02 pyro oven. FD 8401.
Customer set it to pyroclean and the oven door locked and the usual smell of burning grease……then she says it went cold and none of the options on the selector switch would work. True enough, the selector switch was inoperative as if on Auto. It wasn’t the oven lamp was on. 😕 )
I took the top off the oven and systematically pulled off and refitted every wiring connection on the temperature module and hey presto, it started working!! I tested it for a while and all selector switch positions work fine. 😯
So I’m guessing the module unit is at fault. I really really detest pyro cookers.
Any ideas???
Thanks,
Steve.
