NEFF B14M62N0GB cooling fan running all the time
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries NEFF B14M62N0GB cooling fan running all the time
  • #79153
    tinfish
    I’m having a problem with a NEFF oven. According to the customer the glass lamp cover was stuck, so he gave it a belt to slacken it (which worked), but the cooling fan switched on and wouldn’t go off. I assumed that he had damaged the thermostat attached to the lamp holder and replaced it (obviously it all comes as one complete unit), but it is still running all the time. The new thermostat is oc – something tells me it shouldn’t be…
    Any help would be appreciated.
    Grant
    #408170
    nomadPaul
    Re: NEFF B14M62N0GB cooling fan running all the time
    If its the thermostat/time lag switch bolted to the lamp assy then yes , it should be open circuit. It only goes closed circuit once it heats up .
    #408171
    tinfish
    So that doesn’t explain why the fan is stuck on…
    If anyone else has had a similar problem I’d appreciate any input.
    Grant
    #408172
    tinfish wrote:So that doesn’t explain why the fan is stuck on…
    Nomadpaul’s post explains EXACTLY why the fan is stuck on………!
    #408173
    tinfish
    I’ve just re-read my post and realised I’ve written open when I meant closed. Wednesday wasn’t a good evening to try and do anything work related…
    It must be a faulty thermostat on the replacement. The oven had been on earlier in the day, but it was cool by the time I arrived.
