neff B1593NOGB/07 oven
  • #59092
    mbdas
    Hi 🙂
    the fault on this oven is that you can not adjust the oven temp and also when you push the knob in the oven temp display will not go out 😕 has anyone had problems with one of these ❓ has anyone got any tech for this model as well ❓ please 🙂
    Mark 🙂
    #336782
    Re: neff B1593NOGB/07 oven
    Oh dear have you got a right job on with this. 🙁
    Electronic Control Unit could be the fault, very costly though if it’s not that. 😯
    Could also just be the fan element of course or indeed the PTC is a caution too. 😕
    #336783
    mbdas
    I get all the good jobs 🙁
    #336784
    mbdas
    ok I’ve been back and removed toddle device from pcb and cleaned contacts and refitted and i can now set time and temp ok and switch off and on ok. Cool i’ve done it and saved her £170 🙂 but O no customer phoned and said its a lot better but now when you switch it off after between 30 mins and 5 hours it comes back on all by its self 🙁 🙁 with 000 in the temp window
    Can anyone help with this PLEASE ❓ ❓
    Mark
