Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › NEFF B1641 oven dead
- This topic has 6 replies, 3 voices, and was last updated 16 years, 3 months ago by
valentino246.
January 6, 2010 at 12:54 pm #51422
valentino246
ParticipantI have a Neff oven model number B1641A2GB that we were using last night that just popped and stopped working.
I have checked the power from the RCD to the Switch and all the power is present up to the oven. However the lights do not work anymore and there is no clock or fan.It is completely dead.
Could this be the main control unit blown? and is there an easy way to replace this part?
Interesting to know if there are any fuses on it that could be replaced.If not is this part easy to get hold of and is it easy to replace?
All help appreciated.
Peter
January 7, 2010 at 12:29 pm #308007Phidom
ParticipantRe: NEFF B1641 oven dead
Have you checked the terminal block where the mains cable connects to the oven? Sometimes you get a terminal burnt out there if the wiring was not secure.
January 7, 2010 at 2:10 pm #308008valentino246
Thanks very much for that, I will double check the connectors at the rear of the oven.
I did notice some dark burn marks on the main control unit nearest the point where the selector comes out. This is what made me think that that might have blown.
January 8, 2010 at 7:59 pm #308009valentino246
Thanks for the advice. I have checked the connectors and all good no burn marks and power going to the connectors fine. I think I must me the controller unless there is something else you can recomend.
All help appreciated as Neff havbe quoted me £230 parts plus £85 call out to repair it. I can get a new oven for that.
January 10, 2010 at 12:47 pm #308010Phidom
Another thing to check is any thermal fuses or TOCs. Sometimes there is such a device near the top of the oven to protect the controls from overheating.
January 16, 2010 at 6:50 am #308011admin
KeymasterRe: NEFF B1641 oven dead
valentino246 wrote:Thanks very much for that, I will double check the connectors at the rear of the oven.
So you have to replace that main unit ..Do you have warranty ???
January 16, 2010 at 6:10 pm #308012valentino246
In answer to your question
I do not have warranty and it is is the main controller that has failed causing a seam of solder to blow. There is good power everywhere on the machine until the controller where the solder had split away and there is no continuity.
Can you suggest a suitable way forward or is the only alternative now to replace the main controller.
