NEFF B1641S2GB/01
  • #29208
    goosegreen
    Have a problem with above, None of the elements are working Grill,fan and lower. All getting neutrals but no live. Fan and cooling motors working and I can only suspect the control unit but at £163 + Would not want to mis diagnose. The other thing was that the temp display would not zero and started at 50c, Don’t know if this is relevant or not.
    Regards
    Goose
    #222307
    nomadPaul
    Re: NEFF B1641S2GB/01
    If none of the elements are working , i’d start by looking at the temp limiter on the back – if this is open circuit , it will disconnect the live to all the elements
    #222308
    goosegreen
    Cheers Paul Thats the first thing I checked as I have had a couple fail lately.
    Goose
    #222309
    Bryan
    goosegreen wrote:The other thing was that the temp display would not zero and started at 50c, Don’t know if this is relevant or not.
    There is a part listed for that oven as sensor ptc and bearing in mind you’re getting a false temp. reading this may be worth checking.
    Part no. 187586.
    HTH
    Bryan
    #222310
    gegsy
    The 50 deg is the start temp (which can be incremented) and when the temp is reached, the oC indicator in display will extinguisch IIRC.
    If the TOC checks out then its looking like an PTC out of tolerance or more likely the module IMHO 😥
    goosegreen
    Thanks for all the replies, But as I thought the customer was not going to go for a £200 + repair. 🙁 But in all honesty who could blame her!.
    goose
