Neff B1644N0GB/03 all heating elements not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff B1644N0GB/03 all heating elements not working
  • #87459
    swiftguy
    Hope you can help, our trusty Neff Oven B1644N0GB/03 suddenly all the heating elements have stopped working, though the fan, lights and everything else seems to function as normal. You rotate the function selector and seems to go through all the motions but none of the elements heat up – oven, grill, top/bottom heat – nothing.
    Any ideas what this could be? is there some sort of internal fuse for all the heating elements?
    Thanks for your advice and help.
    #434920
    Re: Neff B1644N0GB/03 all heating elements not working
    poss demo mode
    .Turn the function selector from Large grill to Small grill and back again five times.
    ? Demo OFF must appear on the display
    see manual page 48
    swiftguy
    Yes, tried that, just tried it again just in case, no such luck. (No message appears – just wondering whether its worth trying to put it in Demo Mode and then turning it off – but manual does not say how to put it in Demo Mode?)
    One thing I did notice, the display keeps flickering between functions e.g. if its on ‘Circotherm Intensive’, sometimes it will flicker to ‘Circotherm’ it does this with other functions as well.
    #434922
    that may be nothing. depends how they switch the displays
    anyway spare parts listing here
    http://www.neff.co.uk/store/
    could be main board item 0511 page 5
    switch item 0532 page 5
    long shot thermal limiter item 0503 page 5
    I would take the main board out and look for blown tracks. it could also be one of the relay blown on the main board is fixable if you can find out which one and source a replacement and solder it in
    swiftguy
    Just turned it off from the fuse box and turned it on 30secs later, it said demo mode on.
    tried the switching from large to small grill 5 times, nothing on display.
    Other parts of the web said to press the rapid heat button for 6secs – this showed the language settings after 6 secs.
    I just rang Neff to see what they say about this Demo mode business – the guys said to turn it off from the fuse for at least 2hrs! then press the rapid heat button for 10 seconds.
    I’ve turned it off from the fuse and will leave off overnight, lets see what happens in the morning – the family’s Sunday Roast depends on this 🙂
    #434924
    swiftguy
    Looks like my family will be enjoying a Sunday Roast today! – SUCCESS!!! 😀
    Thanks Electrofix for prompting to check the Demo Mode again – I was about to shell out for the Neff Repair+Protect at £14 per/month
    What worked in the end was to switch the selector from large grill -> small grill -> large grill in QUICK succession. Demo Settings Off will briefly appear. I was doing it a leisurely pace before. Hence it didn’t work.
    Full story:(may be will help someone else in the future who falls victim to this)
    This morning, I switched on the oven, display said: ‘Demo Setttings On’. I set the clock. Pressed the rapid heat button for 10secs (a few seconds in the language settings showed). Tried turning on the grill, remained cool. Tried the switch from large grill -> small grill and back (I did it a leisurely pace). (Nothing about Demo on display). Oven still not heating.
    Turned Oven off again at fuse, turned on 1 minute later. ‘Demo Settings On’ was displayed. Tried switching the selector quickly from large grill to small grill and back. ‘Demo Settings Off’ briefly appeared. Oven started working!
    Man, we are so relieved, can’t believe this stupid demo mode has given us all this grief!!
    #434925
    had this fault before on another oven. its only there so they can have it powered up in a public display. some washing machine have it as well
    glad you got it sorted
