Neff B16P42N0GB/04 bulb problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff B16P42N0GB/04 bulb problem
  • #97040
    Keith T
    Hi, I have a Neff oven ENR B16P42N0GB/04 & FD 9109 00104. The oven bulb blew, I have replaced it and the lamp is still not working. I have removed the oven and checked the connections to the bulb holder (pink and black/white striped wires). There is no power to the bulb holder when the controller is set to “oven light”. There is no sign of any damage. Do you have any suggestions? Keith
    #465895
    when select lamp you should hear a faint click from the relay controlling it
    with the power off lift the power board and check for damaged print. Sometimes lamps go with a bang this can weld relays or blow board tracks like a fuse , or both
    its actually a zero ohm resistor they are using as a fuse
    hard to judge sizes by the pic so would need case measurements for the component
    will look around but its the sort of component you could well have to buy 50 off to get one
    Keith T
    Cheers Dave – I’ll measure up and check online as well. There may be another one gone as well (possible burn mark on one end) so may need 2 in the end.
    #465898
    since they are effectively zero ohms or very close a multi meter continuity (buzz) setting will test them
    Keith T
    Thanks again Dave – I’ll check this out
    #465900
    Keith T
    Both zero ohm resistors have blown. I’ll resort to getting a new PCB
    #465901
    that’s a bit expensive when all it needs is 2 new resistors
    Keith T
    I agree and will try to fix it before having to buy a new board. I The resistors are marked with a a single “0”. I tried Farnell and RS but could not be certain about finding a replacement (and without buying a 5,000 unit reel). Do you have nay suggestions Dave?
    #465903
    you need to figure out the case size first as the pic give me no idea of measurements
    once you figure out the case identification which will be something like 2512 then go digging
    found this on ebay
    https://www.ebay.co.uk/itm/100-x-SMD-SMT-2512-Chip-Resistors-Surface-Mount-0R-0Rohm-ohms-1W-5-RoHs/163923848500?hash=item262a9f6d34:g:DnIAAOxyCTtTed4O
    Keith T
    Thanks Dave – I’ll check this out. Footprint is 5.0 x 2.5mm. Much appreciated
