Neff B1920 Fan Oven temp problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff B1920 Fan Oven temp problem
  • #48254
    curly9925
    Our Neff Fan Oven doesn’t seem to be working properly. If you set the temp dial to 180c, it heats up and the indicator light goes out but when checked with an oven thermometer it is only getting up to 150c. The fan is working as normal, so does this mean it’s the thermostat that needs replacing?
    Any suggestions gratefully received.
    #296073
    Re: Neff B1920 Fan Oven temp problem
    Elements either work or don’t, so temperature regulation is the culprit.
    curly9925
    Thanks Penguin, thought it might be. I’ve ordered the part, are there any links to advise on fitting or is it fairly straightforward?
