Neff B4540N0EU/01 Problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff B4540N0EU/01 Problem
  • #75661
    MAW
    I have the above single oven and all the fans and elements have stopped working. However, the display and oven light works and setting the timer makes the light come on and off correctly. When power is first applied the temperature display shows 444 until you select an oven program.
    I have checked that mains power is getting to the main board and all elements are showing resistance and not open circuit. The PTC is showing about 500 ohms resistance.
    Is this a known problem that can be fixed?
    #395778
    Re: Neff B4540N0EU/01 Problem
    I don’t know the machine but, have you checked that there isn’t a thermal cut out of some sort that may give this problem?
    MAW
    Yes there are thermal cut outs between the supply and main board but these are fine
