NEFF B57CR22N0B/38 crazy display
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries NEFF B57CR22N0B/38 crazy display
  • #103174
    washingmachinewoman
    Happy New Year to all!
    Has anyone encountered the following issue on the above oven?
    The customer describes it thus (I haven’t been to the appliance):
    It displays but if you press the control it goes crazy and scrolls through the menu without stopping on anything, so it’s impossible to reset. Apparently controls have been temperamental for about a year but they always managed to get it to behave eventually. Then it showed an error code last month (they can’t remember which one) and they tried turning off at mains for varying amounts of time without result. Also the display has reset to German and to 2014.
    There are two modules, unsure whether that would be the operating module or the control module, or both, or neither? Operating module programmed is around £200, the control module is around £130, so not cheap.
    #492054
    problem as always is it can be either but more likley the control panel
    try giving the panel a really good clean in case its contamination
    Pyro single oven so all electronic.
    Any number of things, depending on how well they’ve isolated the electonics, can send them mental. An earth fault, boards, sensor… the list goes on.
    Even external factors such as, is the supply good, is it clean could affect what it does with your issue being that, if it comes back up and works okay it could be a nightmare to try to pinpoint what’s causing the issue.
    The simple answer is, replace the boards but if it’s not that or those causing it, replacing them will do no good.
    the more complex these get the more interacting problems you get
    Neff can afford to change parts on a whim we cant
    if a clean does not sort it you either tell the customer they pay for the parts even if it does not cure it or walk away and let neff deal with it
    even though the control panel is more likely the fault it could also be corrupted power supply from the power Board and as K says a host of other things
    walk away
    washingmachinewoman
    Thanks K and Dave,
    Much appreciated.
    Having looked at Neff’s repair service, they also charge the parts on top of the £109 callout and labour charge, so not much different from what I would do. Not sure they would charge less for their parts either.
    It’s actually not a pyrolytic clean oven, customer tells me.
    I will let them know all you mentioned and let them decide what they want to do. When you say clean the panel, I assume you mean me cleaning it inside and out, not just an external clean by the customer?
    Lucie
    #492058
    was wondering if any contaminant on the glass on the outside was making the electronics think a finger was on a button
    very long shot i know but its free
    washingmachinewoman
    Ah I see, yes it’s worth a shot. Thanks Dave.
    I hasten to add my callout charge is not £109 by the way
    Lucie
    #492060
    washingmachinewoman wrote: hasten to add my callout charge is not £109 by the way
    Lucie
    if only people would pay it to independants I could gold plate my van lol
    washingmachinewoman
    Spot on advice Dave, the cleaning worked. The customer actually removed the switch front, cleaned the back of it and all is working properly now.
    Lucie
