I have a customer who has this oven, but on the fan oven setting it does not allow heating past 200c as this is the maximum available.
Is there anything that can be adjusted to make the machine go to 220c on fan oven setting.
It will go to this temperature if using the bread function but this also brings another element into effect & causes uneven cooking.
if the unit is not designed to go that high don’t alter it. if you start trying to alter the calibration it will alter it across the temp range. chance are there is no adjustment and its all software controlled
when cooking with a fan oven most recipes tell you to lower the temp. so a fan oven temp of 200 degrees is probably equal to 220 degrees convection unit
Also if you did manage to alter and something went wrong you could be on the wrong side of a law suit
