Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › neff/bosch motor end frame
- This topic has 9 replies, 4 voices, and was last updated 18 years, 7 months ago by
abbots.
September 10, 2007 at 2:54 pm #30434
abbots
Participanthi guys,
neff W4210B1GB/01
carbon brushes gone.
i want to change the motor end frame complete with carbons. neff part number i think is 092025connect and masterpart give me picture of an end frame , but it is different to the one i need, do they fit?
they look like 8 pin end frames, yet the one i need has only 6 pins.
also the housing looks different , it seems to have a motor /drum mounting on it, yet the one i took off hasn’t.
can any one shed a bit of light on this please.
johnSeptember 10, 2007 at 3:30 pm #227181Simon46
ParticipantRe: neff/bosch motor end frame
496872 is substitute part according to BSH.
S.
September 10, 2007 at 3:37 pm #227182abbots
no information at masterpart and connect is a special order.
does any one know if any one else does a replacement part?or does the 096331 fit as well?
thanks.
jkSeptember 10, 2007 at 4:37 pm #227183senseib
Hi Abbots,
Part number 092025 – (motor end frame 6 pin) correct part for that model according to BSH – is available at Qualtex (stock code 016863) £24.38+vat.
Hope this helps,
Brian.September 10, 2007 at 4:43 pm #227184abbots
cheers brian,
i’ll give them a ring tomorrow.
johnSeptember 10, 2007 at 7:17 pm #227185gegsy
senseib wrote:Part number 092025 – (motor end frame 6 pin) correct part for that model according to BSH
092025 has a substitute namely p/no 496872 as Simon rightly mentioned 😀
Dave has these here for the punters http://shop.ukwhitegoods.co.uk/product_ … cts_id=422 as long as you are handy with a soldering iron. Far cheaper option IMHO
September 10, 2007 at 7:27 pm #227186gegsy
abbots wrote:does any one know if any one else does a replacement part?or does the 096331 fit as well?
No, and that has been changed to 496872 😉
September 10, 2007 at 8:02 pm #227187senseib
Qualtex lists alternative part numbers for 092025 as:- 096331, 42B508, 496872 & 844296 – all priced same as original.
Brian.September 10, 2007 at 8:18 pm #227188gegsy
I can only comment on what manufacturer says fit TBH 🙂
September 10, 2007 at 8:31 pm #227189abbots
cheers,
masterpart doesn’t recognise 496872 and connect and maddocks have no stock.
if 096331 does fit either it looks like i’ll have no alternative but to hope qualtex have them in stock.
ta.
john -
