Can anyone help with the Part No’s of the temperature control sensor or the temperature control pcb.
Ordered t/stat for this fridge thinking from parts list on Connect that it was normal Fridge stat type.
Unfortunately is has an electronic board where you would normally expect to find the t/stat with possibly a thermister connected to it to monitor the temperature.
Does anyone know if there is a modification to change from the electronic sensor to the normal T/.Stat.
