Neff C18MT37N0B/06 oven/micro turns off after 5 seconds
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff C18MT37N0B/06 oven/micro turns off after 5 seconds
  • #94571
    tally
    As title Neff C18MT37N0B/06 oven/micro turns off after 5 seconds just started tonight
    i’m away from home so need to wait until eldest son comes home to 3 pin power to its as i cant get to socket so need to turn it off on mains board.
    Questions are what can it be thats failed and repair cost, its 2 years 9 months old so should Neff repair for free as its a £850 ish device. Thanks for your help in advance
    #457723
    Re: Neff C18MT37N0B/06 oven/micro turns off after 5 seconds
    Neff microwaves are built on Panasonic technology and are normally very reliable
    I am assuming the oven (hot) works ok but the microwave side of it causes problems
    As the unit starts the electronics detects the microwave component and check to see if the Magnetron has powered up ok. If the answer is no then the unit aborts the programme
    there is a fuse for just the microwave part that my have blown but beyond that you are heading to dangerous ground with lethal voltages. This is not a job for the untrained
    As for warranty its covered for 2 years anything after that is down to the discretion on Neff who may or may not help you out as a loyal customer
    tally
    Yes its just the microwave , oven works ok
    #457725
    tally
    if its a fuse can you tell what size it will be and can i change it, i wouldn’t go any further than a fuse replacement
    #457726
    fuse is 8A 20mm antisurge microwave fuse
    tally
    its not the fuse as it was working this morning but stopped within 5 mins, spoke to local repairers and they dont touch NEFF and the one’s i search for have terrible reviews. Appointment arranged with NEFF £99 + parts but as its a £1000 + to replace i hope its nothing major.
    #457728
    Most likely be the magnetron
    Bryan
    #457729
    tally
    any idea of cost of part please i cant find it.
    #457730
    tally
    found the problem, the door wasn’t closing properly , soon as it was cleared it worked fine
