hi was hoping for some help with this neff combi m/w oven. cuts out after 2secs when set on microwave fumction.
enr b677no/gb05 fd 870300764
works ok on oven. mag seems (megga tested) ok presumed control board? but which one??! thanks!
Probably both! Just because the mag meggars OK does not mean it good. Check installation/ ventilation.
Mag usually over heats and blows inverter pcb. Assume internal fuse is ok?
Will be the invertor pcb. easy to spot as it has a massive heat sink on it and the solder joints look like a two year 0ld child has done them in the dark!!
