Re: Neff Combi microwave/oven C67M70N3Gb/01
this is normal in fault conditions with the microwave. select microwave and press go, unit runs for about 10 secs and aborts
these units are based on Panasonic units so parts are cheap
there is a fuse on the board that just feeds the microwave. if its intact then its a good chance the mags gone only. if its blown then you will need the inverter and the mag ( faulty mags can blow inverters so its good to change as a pair )
