Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff combi oven/ microwave B6774N0GB05
- This topic has 8 replies, 3 voices, and was last updated 8 years, 4 months ago by
boselecta.
December 7, 2017 at 2:44 pm #92789
boselecta
ParticipantThe fan that sits under the glass lid on the roof of the microwave is noisy and rattling, it seems loose.
Trouble is i can’t seem to identify it or the crescent shape fan impellors on the fan motor shaft.
I know I’m probably proving my ignorance when it comes to microwaves but it would be good to not have to pass it over to the manufacturer for what seems like a faulty motor.
ThanksDecember 7, 2017 at 3:18 pm #452209electrofix
ModeratorRe: Neff combi oven/ microwave B6774N0GB05
assume its the aerial your after its on the page before
part no 495076
December 7, 2017 at 5:16 pm #452210boselecta
ParticipantRe: Neff combi oven/ microwave B6774N0GB05
Thank you that looks the part, Im going to order the aerial motor and the aerial stirrer fan blade.
December 7, 2017 at 6:10 pm #452211electrofix
take it you checked it was that making the noise. had one making similar noises and it was the fan motor 641197 with a loose fan blade
December 7, 2017 at 8:15 pm #452212boselecta
Hi Dave,
Yes definitely that as can hear it clinking around and the shaft feels wobbly.
Just got to work out how to get into the beast, tended to turn down microwave repairs recently.December 7, 2017 at 8:32 pm #452213electrofix
this wave stirrer only turns slowly and the shaft has play because it does not have to be that accurate. to be certain disconnect 1 wire to the drive motor and insulate and try.
this unit is only turning at 9rpm so is less likely to rattle. if you get it wrong with these sort of parts it gets costlyDave
December 7, 2017 at 9:03 pm #452214boselecta
Thanks Dave, didn’t realize it was meant to be loose.
Will go back to check, 🙂December 8, 2017 at 8:33 am #452215SWERV
I would also agree that it is the fan motor part number 641197. I have replaced a handful for being very noisy.
Merv
December 24, 2017 at 11:54 pm #452216boselecta
Thank you for your replies, went back and checked and yes it was indeed the noisy fan motor that I’ve now replaced.
