neff cooker u1421w0gb/01
Home Forums Public Support Forums Help And Support Cooker And Oven Forum neff cooker u1421w0gb/01
  • #10984
    The main fan oven element has burnt out, sparks etc. I changed it but no good. Took the back off and found the temperature limiter was toast. Fitted new one and now the oven works but it has no temperature control. Is there a right or wrong way to fit the limiter, is it the thermostat or something behind the control knob. The top oven works OK. Need urgent reply. Thanks.
    #143443
    Del
    Re: neff cooker u1421w0gb/01
    Hi murrad,
    It has most likely taken out the thermostat when the element blew, this is not unusual.
    It is also pssible that the selector switch that the stat piggy back’s onto may also be damaged because the elements really go with a bang sometimes when they go 🙄
    Remember power off 😉
    Regards
    Del
    #143444
    Dave_Conway
    murrad, you have asked the same question 3 times now.
    You’re new post this morning has been deleted, Del (this post) and litlor here: http://www.ukwhitegoods.co.uk/modules.p … pic&t=7066
    have both answered the question for you, please stop the repeat posts as it is considered as spamming.
    Thanks and Regards
    Dave Conway.
    #143445
    Thanks for the reply DEL I will change the thermostat and go from there. As it turns out I am from Wales and are expecting several visitors from Wales this weekend, hence the urgency to try ang get it fixed before tomorrow. Thanks again. murrad.
    #143446
    Dave_Conway
    Let us know how you get on please murrad 🙂
    Thanks for the email as well, it’s no problem 😉
    #143447
    superfix
    Selector s/w may also be goosed aswell as stat.have known this a few times now.
    Normally when customers have an old fashioned “rewirable fuse box”.
