Hi — This is an odd one. I fitted a main oven selector switch which was different to the orig as in the old switch had all wires screwed in with metal links going to the other switch. As new switch had to be spaded I had no method of putting in these solid wire links. The switch operated the m/c fine. Until customer realised that the oven light now doesn’t work.
I called back to check things and other than these wire links I didn’t fit back on it all seems ok but NO LIGHT bulb is good and there is a slight glow from it but that’s it >> Any Ideas
