neff d/w built in .. s51e50x1gb/24
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries neff d/w built in .. s51e50x1gb/24
  • #92154
    adv
    this runs for about 50 mins then tap light starts flashing ,,, any one know how to get it into test mode .. to find fault code ?
    #450433
    Re: neff d/w built in .. s51e50x1gb/24
    adv wrote: any one know how to get it into test mode .. to find fault code ?
    Nope, not a clue, what’s the point anyway? You have to get more ‘hands on’ and check: –
    Water leakage.
    Blockages
    Flow meter
    Etc
    Whilst cursing in German (I find it helps 😉 )
    #450434
    adv
    no water leakage no blockages . doubt it would fill if flow meter faulty (
    #450435
    When the tap LED flashes is the End LED lit as well? Does it drain at that point? Does the drain pump run continuously or intermittently?
    #450436
    adv
    all need to go back have another look ( thing was working fine when i left ( didnt hang around to see if was heating ,,, if not heating what would it do ? run for a while .. then abort .. then just drain all time and light flash a wonder ?
