Hi guys I’ve got a Neff dishwasher with the tap light flashing I would assume it’s the check water light I called late tonight so I only check the drain pump for blockages. The drain pump constantly runs and wount go off for a long time it does go off but then comes back on it has to be unplugged to stop it happening model number is in picture attached thanks in advance kai
The current going to the pump is used to detect when these are empty. if pump is worn current increases and fools board into thinking it still has water in it
Just a update on this dishwasher I’ve been back to it today and found the float microswitch is faulty,after changing the drain pump contact for the flow meter and a pcb. Kai :rolls:
