NEFF DISH S5433X0GB/13
  • #17751
    alro
    JUST ASKING
    DISH PROGRAMME 65 DEGS SELECTED Mc FILLS WASHERS THEN CLOSES
    DOWN AND STOPS OPEN DOOR AND NO NOENS LIT ON AND OFF SWITCH OK DOOR SWITCH OK
    EMPTY Mc BY LIFTING FLOAT SWITCH UP
    COULD THIS BE A THERMISTAT PROBLEM OR PCB FAULT
    CHEERS ALRO
    #176199
    gegsy
    Re: NEFF DISH S5433X0GB/13
    Has all the symptoms of PCB, if you are getting no leds on when you open door.
    PS Caps off please 😉
    #176200
    alro
    GREG
    SUSPECTED PCB HAD TO SWITCH ON AND OFF A FEW TIMES TO GET IT TO FIRE UP AGAIN DID SAME THING FILLED AND WASHES THEN CLOSES DOWN WITH NO DISPLAY MY THINKING IS THAT IT IS ASKING FOR HEAT WHEN IT CLOSES DOWN
    CHEERS ALRO
    #176201
    gegsy
    Have you checked the plug and socket??
    Maybe overheated and when calling for the heater current, it can’t cope.
    Look at pins of plug top and if you want try plugging appliance into a different socket.
    alro
    GREG
    HAVE MAINS THERE ALL THE TIME + INTO PCB
    CHEERS ALRO
    #176203
    gegsy
    Check the mains supressor, they have a history of failure.
    And for the love of god turn your caps lock off 😈
    alro
    Sorry about caps on will stop this
    just asking how do you get relative topics up from passed faults on appliances for future referrance
    cheers ALRO
    #176205
    At the top of the forum page, look for ‘search’ click on this then enter a simple question or model number, keep it to as few words as possible, select the forum you think is appropriate and hit the return key.
    gegsy
    Hya Jim :wave:
    Hi Greg, you hold him and I’ll hit him. 😆
    Only joking alro, 😀 keep the questions coming, its what the forum is all about.
    jim.
    #176208
    gegsy
    Yours was correct mine was wrong 😳 I deleted my post.
