neff dishwasher
  • #65864
    sandysuds
    Hi Guys
    Can anyone help a NeFF Dishwasher s5555xogb/79 type s911f
    machine wont turn on water tap sign showing ,I changed water valve Now machine display shows when door is open but when i close the door nothing no display
    Sandy.
    #362184
    Re: neff dishwasher
    First of all it is important to realise that the LED’s on the display only illuminate when the door is open. When you shut the door they go off anyway, that is normal.
    Also, water tap indicator illuminated often means the machine can’t drain (i.e Drain pump impellor jammed etc) so do check out the pump.
    HTH? 😀
    #362185
    sandysuds
    Re: neff dishwasher
    Thanks for your help once again martin much appriciated
    It worked a treat
    Sandy.
    #362186
    Re: neff dishwasher
    Drain pump jammed was it?
    #362187
    sandysuds
    Re: neff dishwasher
    yes a sliver of glass
    #362188
    Re: neff dishwasher
    Nice one! 😀
