Neff dishwasher
  • #70588
    cornflakes
    Model
    S44E43W0GB/29
    FD8712
    had recent call to the above
    problem was no water intake
    Water light ON
    worked problem back to inlet vakve, as when hit with pliers..valve opened
    Have revisited and replaced valve with Neff replacement
    Switched on to test..unit filled and ran through its full cylcle
    Cleint set up on timer last night..no action whats so ever.unit sat with
    Active light ON
    Water Light ON
    client has done re-set proceedure withdirect connection to unit,less timer switch
    it just times out on drain pump and sits with above panel lights on ( no water intake)
    any help appreciated
    #378462
    WhiteVanMan1
    Re: Neff dishwasher
    I’m not sure which one this is, but after a recent problem I had, it it has the impellor jug fitted, that is what I would go for. It could be the aquastop valve if it has aquastop. I kow it’s a bit vague, but hope it may be of use. Steve.
