Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Neff Dishwasher
- This topic has 9 replies, 4 voices, and was last updated 17 years, 12 months ago by
philharr.
April 14, 2008 at 1:23 pm #35997
philharr
ParticipantI have a problem!
I came to my dishwasher this morning and the pump is still running. The dishwasher is empty and I have had a poke round the impeller and it is moving freely. The programme buttons make the lights change but nothing happens and the reset buttons don’t do anything.
It looks like a new Control Module to me or is there something I should check before I change it.
April 14, 2008 at 6:49 pm #249065Penguin45
ParticipantRe: Neff Dishwasher
Flood protection activation will run the drain pump continuously. Base may have flooded due to a water leak – this will also over-ride any programming.
Power off before removing any panel, please.
April 14, 2008 at 6:50 pm #249066smartin
affraid we will need the model number its etched on the stainless steel door as you open it, but it sounds like the flood protection has activated meaning the base has flooded but remember to remove plug before you investigate smartin
April 14, 2008 at 6:53 pm #249067Penguin45
:waving:
:p45:April 14, 2008 at 7:07 pm #249068smartin
lol beat me to it
April 16, 2008 at 8:56 am #249069philharr
Model number s5543x1gb/13
Is the problem likely to be water beneath in machine or in the base of the machine itself? If I find the water problem will the sensor reset itself or will I have to find it and re set it?
April 16, 2008 at 8:58 pm #249070Penguin45
The white plastic tray that the machine is built onto is the base. If it floods, there is a polystyrene float mechanism in the front left corner which will switch on the drain pump and over-ride the programming. Lid and side panels off to investigate – power as well.
April 19, 2008 at 5:55 pm #249071philharr
Checked for water. Tray totally dry – no sign of ever being wet! Any other ideas?
April 19, 2008 at 6:10 pm #249072Penguin45
In that case almost certainly the PCB has bought it.
April 19, 2008 at 6:19 pm #249073gegsy
An email to spares@ukwhitegoods.co.uk quoting p/no 264882 will get you sorted. (app £100 odd)
:p45:Greg
